Background: Vehicle sat for a while due to my job (roughly a year). Came home, put a new battery on it, fired right up. Changed all fluids, would start, then shuts off. Isolated the problem to a bad Ignition Control Module. The previous owner didn't care about how they "fixed" things. I had some time off, so I replaced some wiring and re-terminated some connections. Vehicle ran fine, then quit running. Found the coil to bed bad. Replaced it. No spark to the plugs. Replaced the distributor, got weak spark, but it wouldn't fire. Now, I do not have any spark. Everything that deals with the ignition is new, except for the actual ignition switch and the starter solenoid. I have +12 volts to the plug wire feeding the top of the distributor cap.
I believe the problem to be somewhere in the wiring. I hired a mechanic to get it running. They failed. They redid some of the wiring and now I am not sure what goes where. I would like to verify that all of the wiring is correct. However, I cannot find a diagram with proper colored wires. This is all the old Prestolite stuff. I am not ready to upgrade the ignition just yet. I have a few other things I want to fix on it first.
I believe the wiring from the the ICM is a great place to start. It has five wires: Black, white, blue, green, yellow. However, the plug it connects to has red, blue, green, yellow. I want to verify I have the plug side going to the right spots first. I know two of them go to the distributor, one to the Ignition, one to the coil, and the black to the ground (I have it grounded to the engine).
Sorry for the long post, I figured it would be best to give as much information up front as possible.
Feb 27, 2019 at 6:39 AM
