No spark
1992 TOYOTA PICKUP
100,000 MILES • 3.0L • V6 • 2WD • MANUAL
PACIFICISLANDER
  • 240 POSTS
Location of the crankshaft position sensor and ignition system diagram needed.
Jul 22, 2020 at 2:58 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
There is no external crankshaft position sensor. Engine speed is sensed via pick-up coils inside the distributor.The information is then sent to the ECU to determine crankshaft position and engine rpm.What type of ignition system diagram would you like? Wiring diagram? Spark plug wires? Let me know.Hope this helps and thanks for using 2CarPros.
Jul 22, 2020 at 2:36 PM
PACIFICISLANDER
  • 240 POSTS
Yes Sir, if you could kindly sent me the ignition system wiring diagram, spark plug wires and firing order. Thank you
Jul 22, 2020 at 2:42 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here again is the information you requested for diagrams. I've attached pictures below.Hope this helps and thanks again for using 2CarPros.
Danny-
Jul 22, 2020 at 5:05 PM
PACIFICISLANDER
  • 240 POSTS
I have no spark. looking for the CPS and asking for diagram and where to start.
Jul 23, 2020 at 12:09 AM
PACIFICISLANDER
  • 240 POSTS
The problem, there's is no spark. I nailed it down to the PCM. Thank you.
Jul 24, 2020 at 1:27 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Glad to hear you found the ECU problem. Hope you will use our site again if needed.Thanks again for using 2CarPros.
Danny-
Jul 24, 2020 at 3:29 AM
