My first suspect is the crankshaft position sensor. If it came disconnected or has gone bad, you will lose spark. The easiest way to check it is by using a live data scanner and checking to see if there is an RPM signal when cranking.
Here are two links. One discusses symptoms of a bad sensor, and the second discusses how, in general, one is replaced.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Here is a link the discusses the most common reasons for a crank no start condition:
______________________
If you determine the sensor is bad, here are the directions for replacement specific to your vehicle. The attached pictures correlate with these directions.
ROCEDURES
Fig. 9 Crankshaft Position Sensor
See Pic 1
REMOVAL
1. Remove speed control servo from driver's side strut tower.
2. Remove crankshaft position sensor retaining bolt Fig. 9.
3. Pull crankshaft position sensor straight up out of the trans-axle housing.
4. Disconnect crankshaft position sensor electrical connector from the wiring harness connector.
INSTALLATION - ADJUSTABLE
Some vehicles may be equipped with an adjustable crankshaft position sensor. This can be identified by an elongated mounting hole in the sensor.
Fig. 10 Crankshaft Position Sensor And Spacer
See pic 2
If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the face of the new sensor Fig. 10.
1. Install sensor in trans-axle and push sensor down until contact is made with the drive plate. While holding the sensor in this position, install and tighten the retaining bolt to 12 Nm (105 in lb) torque.
2. Connect crankshaft position sensor electrical connector to the wiring harness connector.
3. Attach connector to heater tube bracket.
4. Install speed control servo. Tighten nuts to 9 Nm (80 in lb) torque.
INSTALLATION - NON-ADJUSTABLE
1. Install sensor in trans-axle.
2. Install and tighten the retaining bolt to 12 Nm (105 in lb) torque.
3. Connect crankshaft position sensor electrical connector to the wiring harness connector.
4. Attach connector to heater tube bracket.
5. Install speed control servo. Tighten nuts to 9 Nm (80 in lb) torque.
Let me know if this helps. Also, this engine does have a timing belt. When cranking to start, does it sound normal, like it is turning faster than normal, uneven?
I hope something here is helpful. Let me know if you have questions.
Dec 4, 2018 at 6:06 PM
