Long story short I have the car listed above and the A/C starting going out until it did not work anymore.
1. System has been flush and recharged.
2. Orifice and expansion valve has been replaced.
I have visited 4 different shops and nobody can find what's wrong with it.
the last shop said it was something electrical since the ECM was not sending power to the A/C pressure Sensor, so I went ahead and bout and reprogram a new ECM and nothing.
The bottom line is the compressor its not coming on but if I jump 30, 87 compressor comes right on with no problem. Looking at the electrical diagram the wire 63
dark green/white is the signal wire that supposed to command the relay to turn on and off?
I really don't know what to do anymore I really need some help.
I also was reading a similar thread here and one guy did everything swap lots of parts and it end up been the compressor? will the compressor still be bad it it engages manually by jumping wires? post stated he could manually jump compressor too and it will come on.
Sep 2, 2019 at 1:29 PM
