Here are some number that I ran today at idle for about 15 minutes in my driveway after parked for about 1 hour 15 minutes. The truck does have a lack of power going up hills with some noise. I hope this helps.
Fuel system 1 statusCL
Fuel System 2 statusCL
Calculated Load Value(%)12.2
Engine Coolant Temperature(°F)181
Short Term Fuel Trim -Bank 1(%)1.6
Long Term Fuel Trim - Bank 1(%)-5.5
Short Term Fuel Trim -Bank 2(%)4.7
Long Term Fuel Trim - Bank 2(%)-3.9
Fuel Rail Pressure(gauge)(kPa)52.2
Intake Manifold Absolute Pressure(kPa)4.1
Engine RPM(rpm) 536
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(°)20.0
Intake Air Temperature(°F)125
Air Flow Rate from Mass Air Flow Sensor(g/s)0.01
Absolute Throttle Position(%)12.5
Location of Oxygen SensorsB1S12--B2S12--
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.730
Short Term Fuel Trim Bank 1-Sensor 1(%)1.6
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.700
Short Term Fuel Trim Bank 1-Sensor 2(%)N/A
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.800
Short Term Fuel Trim Bank 2-Sensor 1(%)4.7
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.700
Short Term Fuel Trim Bank 2-Sensor 2(%)99.2
OBD requirements to which vehicle is designedJOBD&OBDII
Fuel Rail Pressure(kPa)527.9
Commanded Evaporative Purge(%)17.6
Fuel Level Input(%)25.9
Evap System Vapor Pressure(Pa)-0.683
Barometric Pressure(kPa)14.5
Catalyst Temperature Bank 1,Sensor 1(°F)667
Catalyst Temperature Bank 2,Sensor 1(°F)631
Control module voltage(V)13.969
Absolute Load Value(%)14.1
Commanded Equivalence Ratio0.999
Relative Throttle Position(%)2.4
Ambient air temperature(°F)111
Absolute Throttle Position B(%)12.5
Accelerator Pedal Position D(%)20.0
Accelerator Pedal Position E(%)9.8
Commanded Throttle Actuator Control(%)3.1
Type of fuel currently being utilized by the vehicle GAS
Intake Air Temperature Bank 1,Sensor 1(°F)125
Intake Air Temperature Bank 1,Sensor 2(°F)140
Commanded Fuel Rail Pressure A(kPa)580.1
Fuel Rail Pressure A(kPa)630.9
Fuel Rail Pressure B(kPa)623.6
Jun 16, 2021 at 7:34 PM
