It sounds like you have a couple different problems. The first thing I want you to check is fuse 18 in the under hood fuse box. In addition to just checking the fuse, confirm there is power to it. Here is a link that will help:
Next, in the attached pic, I highlighted the light green wires that power the back up lights. If the fuse is good, I need you to check if power is going to the lights. If there is, then check the two grounds I highlighted. You can simply check for continuity to ground via the black wires at the light socket.
If you look at pic 2 below, I highlighted two fuses. Fuse 18 is the one I mentioned above. Fuse 31 is for the instrument panel. Check both and confirm power is available.
Let me know what you find.
Aug 3, 2020 at 10:05 PM
