No reverse
2007 DODGE DAKOTA
180,000 MILES • V6 • 2WD • AUTOMATIC
ZACHARY DYAR
When I put my truck into reverse all that happens is the engine revs when I push the gas pedal. All other gears work fine. There was no warning at all this would happen. I parked it at work with reverse working fine, and when I got off work it wouldn't reverse at all. What could this be?
Nov 26, 2019 at 5:10 AM
Good morning,
Most likely the reverse clutch inside the transmission has failed. That would require the removal of the transmission and inspection for the failure.
https://www.2carpros.com/articles/automatic-transmission-problems
How long since you changed the fluid and filter?
Nov 26, 2019 at 5:29 AM
ZACHARY DYAR
I just changed the fluid and filter. But it was after I lost reverse. It's my girlfriend's truck and it was her step dad's before her and from what I'm gathering it wasn't maintained at all.
Nov 26, 2019 at 9:34 AM
I understand.
Sorry, no easy fix for this one. You need either a used transmission or a rebuild.
Nov 26, 2019 at 9:40 AM
