We have two ways to begin testing. First and the easiest is to perform a scan of the can-bus to see what codes are stored.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires so they can communicate with each other. This type of scan will retrieve codes regardless of the module storing them. In this case, scanning will likely point us to a pressure sensor or an internal fault.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Or we would need to confirm transmission line pressure is within spec when the vehicle is placed in gear. This requires testing transmission line pressure and is a little more time consuming and dirtier job. LOL
I just went to the manual to get you the directions, but I have a problem. The manual for this vehicle requires scanning for codes first so the correct test is performed. Ugh!!! Sorry about that. Normally, there is a general line pressure test procedure.
Let me know if the scan is something you can do or have done.
Apr 10, 2023 at 7:36 PM
