No reverse
2000 CHEVROLET TRUCK
96,000 MILES • V8 • 4WD
RICKPARKS
  • 4 POSTS
Was stuck in snow on a downward angle. . Had to back out.. After awhile wheels stopped spinning and reverse gear didn't engage. Checked fluid level was ok. Have no reverse. Is this something I can fix myself?
Dec 14, 2016 at 8:00 AM
STEVE W.
  • 15,113 POSTS
Take it for a drive, bet you find it winds out in first then jumps into third and that you have no overdrive as well. Common failure in that trans is the sunshell. GM had a bad run of parts and they strip the teeth or shatter the ring on the shell. The repair is to rebuild or replace the transmission.
Dec 14, 2016 at 9:59 AM
