This flow chart has all kinds of adapters, you should be able to check the resistance without them, it's just a coaxial cable, the center pin is the signal pin and connector is the shield that runs through the cable around the center wire for interference purposes.
Diagrams 9,10 are for the Radio removal, but these cables running along the passenger side floor, and up the C pillar, you may be able to find them in that area, because with pulling the radio, there's additional instructions on pulling the glove box as well. I'll post them too, but also check for any codes stored throughout the vehicle, have you done a full system scan yet?
Jun 8, 2024 at 10:39 AM
