After having the truck jumped the radio, wipers and HVAC do not work
1992 TOYOTA PICKUP
200,000 MILES • 3.0L • V6 • 4WD • MANUAL
EMILYF.
I got my truck jumped, I don't know if it's related? My wipers, radio and AC/heat will not work? Check the fuse? And the lighter never worked.
Aug 12, 2020 at 8:26 AM
Looks like you may have a couple fuse issues. These systems have separate fuses so we need to check them and make sure they are okay. They are all located in the junction box 1 so let's check there first.
Since you had the vehicle jumped have you replaced the battery? More then likely your battery is weak so we need to check that and make sure it is okay. Here is a guide that helps with this:
Let me know what you find and we can go from there. Thanks
Aug 12, 2020 at 4:31 PM
