No power steering nor brakes
2004 CHEVROLET AVALANCHE
149,000 MILES • 5.3L • V8 • 2WD
JOEL SANFORD
I have no power steering and no brakes. Does the power steering develop the vacuum for the hydraulic assist brake?
Jun 25, 2018 at 9:11 AM
Good morning.
Do you have a diesel engine?
The power steering pump provides pressure to the hydro boost and the steering gear. If the pump fails, you will lose both.
The first thing I would do is to flush the system completely with at least a gallon of fluid to get any debris out of the system. If that does not work, then it may be the pump.
Removal Procedure:
imageZoom/Print
1. Remove the power steering pulley.
2. Raise the vehicle.
3. Remove the oil pan skid plate bolts.
4. Remove the oil pan skid plate from the vehicle, if equipped.
imageZoom/Print
5. Place a drain pan under the vehicle.
6. Remove the power steering pressure hose (2) from the power steering pump from underneath the vehicle.
7. Lower the vehicle.
imageZoom/Print
8. Remove the clamps (3,5) retaining the power steering return hoses to the power steering pump and remove the hoses.
9. Remove the lower intermediate shaft from the steering gear.
imageZoom/Print
10. Remove the bolt retaining the rear bracket to the engine.
11. Remove the bolts from the front of the pump.
12. Remove the pump from the vehicle.
Jun 26, 2018 at 5:34 AM
