No pulse to injectors?
1995 CHEVROLET ASTRO
1,242,345 MILES • 3.4L • V6 • 2WD • AUTOMATIC
ASTROWAY
Van quit running and hasn't run since. The fuel pump runs, fuel pressure, checked relay checked, van will start and shut off with starting fluid into throat.
May 15, 2025 at 3:29 PM
ASTROWAY
How do I get pulse back to injectors?
May 15, 2025 at 3:31 PM
If a fuel injector shorts out it will cause the injector driver inside the ECM to shut down. I would start by checking the ECM/IGN fuse which is in the fuse panel on the left side of the dash. here is a guide to help check the injector and to see if the ECM is sending a pulse signal.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let's run the codes as well.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Please go over these guides and get back to us.
May 16, 2025 at 12:06 PM
