No power sputters and shuts off
2002 NISSAN MAXIMA
140,000 MILES • 3.5L • V6 • 2WD • MANUAL
JENNYMAXED02
Starts up fine cold. Cold drive no power, warms up sputters, spits, then stalls. Not driveable and rpm's seem sluggish. There are no codes or lights.
Jan 10, 2018 at 11:29 AM
It sounds like you have a fuel pump going out, but before we go there lets run the codes to see what come up.
Please run this test and get back to us.
Jan 11, 2018 at 1:30 PM
JENNYMAXED02
Tortured drive to local Auto Zone. Had them test and with same results. No code or lights, while on, off, standing idle, or driving. Any tricks as to how can I test fuel pump relay or filter?
Jan 12, 2018 at 11:05 AM
Yes, here is a guide to help you test the fuel pump relay and the fuel pressure. You will need an adapter which comes in the kit you can rent from the auto parts store for free.
Here are the guides:
Pressure should be between 45 and 55 psi.
Jan 12, 2018 at 11:15 AM
JENNYMAXED02
Thanks Ken,
Great Links !! Get back to basics just like the old days ; spark , fuel , & air ! Was so DEPENDENT on code & lights that I almost went to the local dealer ; & would have dropped a weeks take home just to test.!
Thank You for hitting MY reset button ; LOL !!
Best Regards,
JennyMaxed02
Jan 13, 2018 at 9:02 AM
Good to hear, please use 2CarPros anytime we are here to help.
Jan 13, 2018 at 8:00 PM
