I got a 2001 Mitsubishi galant that I can't get to start. I got in the car to start it and it started for about 2 sec and then died and won't start back. the fuel pump is not kicking on so I took it out and hook it up directly and it worked so I changed filter and put back in and again it would not work. So I changed the fuel pump relay and still wouldn't work. So I took the old pump back out and hooked up a new fuel pump, and again it did not work. I checked to see if there was power to the relay and I got nothing with the key off and the key on. So my question is, what would cause there to be no power to both the fuel pump and the relay... and it does have the anti theft system equipped...
Feb 23, 2015 at 12:10 AM
