few days ago the car didn't start when cranking it over and over. eventually it did end up starting until yesterday it has done the same thing and not yet started. I have checked the fuse and seems good. I found the fuel pump under the back seat and disconnected the wire harnesses to it and used a cheap test light to try and find power but could not. I made sure the key had been on for only a few seconds before turning off key and turning on again but still nothing. I then switched a relay from another relay under the hood that was for high speed cooling fan, but still didn't crank. maybe that relay was bad too? maybe its not a relay at all maybe im really an idiot and not connecting the test light correctly? any guidance here?
Apr 14, 2014 at 6:39 PM
