no power to the fuel pump fuse
1997 CADILLAC DEVILLE CONCOURS
100,000 MILES • 4.6L • V8 • FWD • AUTOMATIC
KELLYZ
  • 4 POSTS
Installed new head gaskets. Got everthing back together it said check fuel system. Installed new fuel pump. I hsve no power at the fuel pump fuse. I did have the PCM unplugged when i removed the engine cradle.
Mar 23, 2015 at 9:16 AM
HMAC300
  • 48,601 POSTS
if you have a different key try that as it may be the diode in it. then check fuse with a test light as it may be the fuse block not making good contact causing problem.
Mar 23, 2015 at 9:33 AM
KELLYZ
  • 4 POSTS
The key didn't work. I don't know where the power comes from to go to the fuse. I have no power to the fuse. Is there another fuse somewhere?
Mar 23, 2015 at 2:29 PM
HMAC300
  • 48,601 POSTS
check items in right fuse box underhood. It may be the maxi fuse or ignition relay not good you can replace relay with a like relay or go to repair electrical how to test a relay on our site here. The fuse is a larger one that is 40amp see pic
Mar 23, 2015 at 3:04 PM
