The battery was drained, I jumped it off and left running to charge. I forgot about it until the next day. It had run out of fuel. The ignition was left on. (I know really dumb) I added fuel but it will not start.
I replaced the fuel pump, open circuit relay and EFI relay. Still no power to the fuel pump.
I tested the new fuel pump with twelve volt jumper wires and it works. I have twelve volts coming to the electronic relay.
I am getting no voltage to the fuel pump. What else should I try?
Jun 6, 2018 at 7:20 PM
