Gotcha, So fuse # 12 in the fuse panel (BCM) on the left side of the dash must be good so please double check that. IF that is good I would check the HVAC controller ground which is located at the center of the dash G206, here is a guide to help you check the power and ground for the system with the wiring diagrams below to help as well, if you have power and ground the HVAC controller is bad and it need to be replaced.
Apr 23, 2026 at 8:38 AM
