Got some weirdness. Everything pointed to a fuel pump. No pressure at the schrader valve on the fuel rail. 12v at the relay, 0 ohms over to the 20a fuse. The other terminals of the relay get 5vdc when the key is turned to crank.
Cut hole in floor of van (i have no lift), replaced pump. Same issue. Checked wiring at pump, no voltage at the pump!
Digging deeper, changed with known good relay, same result, confirmed the 30 spade gets 12vdc. Jumped 30 and 87, confirmed 12vdc at the fuse, and fuse good.
Here's the weirdness: When the key is off and out, both terminals of that fuse are seeing 4-5vdc. When the relay is back in and the key is turned im only getting 7-8vdc. I don't know if it is related or not. When i am trying to take apart the fuse box with the 3 10mm bolts, when they are all loose, nothing works, dash dead, key gets nothing. Should those bolts control the power flow of that whole fuse box?? How does that box come apart?
I'm thinking corrosion in the box. What else can i test?
Aug 6, 2021 at 8:22 AM
