I'm looking for a wiring diagram for the vehicle listed above. I am dealing with crank runs then like 2 seconds later. I thought it was probably a pass lock issue, but I tried the 30 minutes relearn and didn't change. Fires right up then seems like fuel pump isn't working. So, I was trying to jump the relay but like a rookie I accidently jumped 86 to 30 and it sparked not no power. To the relay not constant or when turn the key. So, I'm assuming I blown something, hopefully a fuse. But all the simple fuses look fine. Where should I start to look?
Mar 27, 2023 at 10:51 AM
