That sounds like the antitheft light. If the vehicle doesn't recognize the key being used, it will actuate the immobilizer and not start. In the event of a blocked Immobilizer system (unauthorized key), the ECM control unit locks the engine control by cutting off the ignition circuit and the injector circuit. If the key you have was never programmed, that is the problem.
I went through reprogramming the immobilizer, and it requires a scan tool that has programming software. I can't say that only a dealer will have one, but that is where I would start. Also, if there is a good locksmith, they usually have the ability to do this.
I tried to find an alternative technique, but there is none.
Let me know if this helps. Also, let me know if that takes care of the issue.
May 13, 2022 at 7:32 PM
