I have the sport model. I got the car and it had a broken timing belt, when it broke it bent all the valves, so I replaced both heads and cam and crank sensor as the belt ripped the wires when it broke, I got the car to start and run, but it developed a very unusual problem, sometimes when I was driving it would just shut off even a cruising speeds, I would coast to the shoulder and it would start right back up, then one day we went out turned it off and did our errands came out and it would not start, so had it towed home, I checked I was getting spark but no fuel, replaced fuel pump, still no fuel, checked no power to fuel pump, so at this point I've replaced, PCM, immobilizer, key switch and key all programmed together, fuel pump replace, MFI replay, fuel pump control module I have no codes at all. I found corrosion on the wiring just above the relays, as the harness comes out from the firewall, took the harness apart and the wires looked corroded and spliced not factory, order a used harness off of eBay installed it, everything fits. But no plug for the fuel pump control module.so I am not sure what to do at this point.
Dec 13, 2018 at 6:48 PM
