No power to fuel pump
1987 MAZDA 626
114,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
PATRICK JAY SCHOLTEN
I am not getting power to the fuel pump. Is there a fuse or relay that I need to check out? The fuse panel lid is missing so I do not have a diagram.
Mar 27, 2017 at 2:53 PM
HMAC300
  • 48,601 POSTS
main relay #2 goes to fuel pump as well as a few other things it just shows it under hood by battery see pic
Mar 28, 2017 at 9:44 AM
I checked those. They are good. Shouldn't there be a separate relay for the pump. So it primes when you turn the ignition switch on.
Mar 28, 2017 at 2:29 PM
HMAC300
  • 48,601 POSTS
not according to the wiring diagram the one runs the pump you could have a bad pump. Check fuel pressure although you may need an adapter to test it if no Schrader valve on fuel rail.
Mar 28, 2017 at 3:14 PM
