Hello, these Hyundai's can be difficult with service information. So, this has a Push button ignition with a smart key you just need to have inside the vehicle with you, correct? I just want to make sure I'm following these Power diagrams.
Can you first check that the Stop LP Fuse 15Amp and the IG Fuse 30amp in the engine compartment fuse panel have power. They should have battery voltage all the time. These diagrams jump back and forth through 6 pages, so let's see if we have power starting there.
The power for those 2 fuses comes from a long Multi Fuse which is a long Fuse bar looking thing, don't try to pull it out, just first verify power on those 2 fuses first.
Also be careful about swapping relays around, this is not recommended anymore due to the unique system relays used now, most relays are now designed for use in only one location and should not be swapped with other relays even if they look the same.
Sep 8, 2023 at 2:26 PM
