I bought the car barely running. I towed it home. Upon putting my scanner on it. It had four codes, cylinder 1, cylinder 3 injectors open circuits. Coil e cylinder 5, f cylinder 6 open circuit. I began by pulling the intake manifold to get to cylinders 2, 4, 6 unplugging all of the injector and coils, i turned on my multi-meter put negative probe to battery ground and probed the plugs on the coils and injectors. There is no power to either. Fuse # 37 25 amp for ASD keeps blowing when key is "on". I have tested the ASD relay and it is good. Replace the relay fuse. Still no power. Any ideas what to look for next?
Aug 5, 2019 at 7:58 PM
