I have a feeling I know what is happening. This vehicle has a totally integrated power module (TIPM). They have connectors that have (as far as I'm concerned) too many pins. As a result, the pins are small and prone to damage, corrosion, and breakage. I suspect that is where the short is.
The idea that you get power for a couple seconds and then lose it to the ASD is likely being caused by a poor connection that can't handle a load.
So, the TIPM is basically the power distribution box under the hood. Under the fuses are the modules. We need to check the connectors for damage or corrosion.
Before you start, disconnect the negative battery terminal. There are several different connectors. I attached several pics below. Primarily, we are looking for the connectors related to the ASD. I highlighted the connector numbers, the pin locations in the connectors, and a legend showing the purpose of the pin.
I suspect the TIPM is going to need to be replaced. A power supply that drops off is a common symptom with these when they fail. But the best thing to do is confirm there is an issue. It isn't a cheap part.
Let me know what you find.
See pics below.
Sep 11, 2023 at 8:23 PM
