No power to A/C compressor
2008 NISSAN ALTIMA
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
AMANDAG10304
Not getting power to the compressor from the IDCM. When I do the test (pushing the door button 10 times and it runs through the test on wipers, compressor clutch etc) it engages the clutch so I know that the relay is good. We have the system evacuated and refilled to correct pressure, new o-rings and system has no leaks, new pressure switch, new IDCM. Can't figure out why it's not getting power. Could it be the control inside the car? When we turn it on it blows hot air. Please help.
Aug 4, 2021 at 2:54 AM
Good morning,
First, you need to be sure you have freon in the system. You need at least 30-40 pounds for the ECM to ground the relay to turn on the system. You will need to check the system with gauges.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
I attached the wiring diagram for you as well. I circled the fuse you need to view to be sure the relay has power.
I also attached the location of the relay for you to view.
Aug 4, 2021 at 3:12 AM
