No Power to A/C Clutch?
2017 CHEVROLET SUBURBAN
110,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BBHEPP
I am not getting power to the AC clutch. I can't find a wiring schematic to figure out if it's the temperature control module or something else. There is no relay for this year.
Apr 13, 2023 at 11:18 AM
I attached the entire wiring schematic for the AC circuit below, so you have it as a reference.
I read through the schematics, and it does show an AC clutch relay in the under-hood fuse box. It is actuated by fuse 60 which I can locate in the pics. However, they didn't indicate the relay location or number.
In most cases, the relay is located close to the fuse. Take a look at the pics below and let me know if they help.
Take care and let me know what you find.
See pics below.
Apr 13, 2023 at 7:50 PM
BBHEPP
I've checked the fuse and it is good. I've read that the AC Compressor Clutch Relay should go in location 29 Uplifter 2 Relay, but this vehicle never had a relay there. I can't find any mention of or location for the Engine Controls Ignition Relay. Could the ECU be going bad? Any Ideas?
Thank You
Apr 14, 2023 at 11:57 AM
You are correct about the relay location. I looked up the uplifter 2 relay. It is for police provisions. See pic 1 below. When I follow the power supply back, it takes me to multiple things but nothing with the AC.
I believe engine controls (ECM) and ignition are the two I highlighted in pic 2 below. Take a look and let me know if that is what you are seeing.
See pics below.
Apr 14, 2023 at 7:17 PM
BBHEPP
I checked all the fuses and relays in the engine compartment, they all came back good. I also did a wire trace from the ac clutch and the only place I got good tone in the fuse box was at TP1 shown in the photo. At this point I am lost and don’t know where to go from here.
Thank you
Apr 15, 2023 at 7:04 AM
It took me an hour, but I finally was able to determine why you can't find the relay. It is integral to a printed circuit board in the fuse box. See pic 1. According to my findings, it is not serviceable.
I suspect the box will need to be replaced. I attached diagnostics below that require a bi-directional scan tool to perform.
Take a look and let me know your thoughts.
Apr 15, 2023 at 9:16 PM
