No power steering. Put pressure gauge on vehicle. Started car 80PSI on pressure gauge. Turn wheels all the way pressure goes to 1,300PSI. Manually closed the valve on pressure gauge no increase at all when I deadhead the pump. Guage reads zero. Pressure should build up if I'm restricting the valve. Correct? Bought rebuild kit for pump but not sure if a couple of gaskets will fix it. Any ideas?
Jul 6, 2022 at 5:39 PM
