No power pulling a hill
2001 OLDSMOBILE INTRIGUE
75,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MCGIVER18
My car starts and runs and sounds fine, no noise. It has no power pulling a hill. What is the problem?
Sep 21, 2018 at 8:21 PM
Whenever someone mentions a loss of power, the first thing I suspect is a plugged catalytic converter. Take a look through these two links. One discusses symptoms and the other how to check for a plugged converter.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
If the check engine light is staying on, have the computer scanned. Most parts stores will do it for free. If there is a trouble code or codes retrieved, let me know what they are so I can better guide you.
Let me know what you find.
Sep 21, 2018 at 8:30 PM
MCGIVER18
Okay, well I had the catalytic converter checked out and everything is good nothing wrong with that. Is there anything else that it could be?
Sep 22, 2018 at 12:08 AM
If the converter is good, there could be a few other things. Has the check engine light come on? Have you checked fuel pump pressure? Have you checked for a vacuum leak?
Let me know what has been done so far. I attached three links. The first discusses different reasons for low power. The next two I included if you wanted to check fuel pump pressure or for a vacuum leak.
Sep 22, 2018 at 5:35 PM
