no power popping noise
1996 CADILLAC ELDORADO
136,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
PATRICKSCADILLAC
Description of Problem: I have 1996 Cadillac Eldorado 4.6 Northstar, it threw a code for fpr so I replaced it. I also replaced the spark plug wires and plugs. I had the coil packs and coil pack board checked and my cat checked, they're good. The problem is when I'm at a dead stop and I give it gas it has no power and it makes popping sound towards the passenger side, but when it gets up to around 20 mph it picks up on power.
Mar 10, 2016 at 5:42 PM
HMAC300
  • 48,601 POSTS
Check fuel pressure with a gauge and check compression it may be a valve problem. Most auto part stores rent that gauge.
Mar 11, 2016 at 8:09 AM
