Originally the problem with this car was that it was running hot and leaking coolant. So apparently the mechanic had replaced the water pump, then for some reason diagnosed the radiator fan as inoperable. So, he spliced the two wires on the connecting harness to the fan to go to the ground where the battery ground is bolted to in front of the strut, and the positive wire was run into the vehicle and wrapped around the 5A crank fuse.
The vehicle did try to start, but it made a sound similar to when one is out of gas (that is, just keeps turning and turning). However now not even the lights come on in the cabin, nor will it attempt to crank. The battery has been tested as good, and we are now just throwing anything at it as to what may be a solution.
Jul 3, 2018 at 10:06 AM
