When you turn the ignition, no crank, no lights, nothing and the only way to remove the key is to remove the top cover of the column and press the solenoid over for the release. What has gone wrong, drove fine, no issues when I drove it last.
Reviewing videos, makes me think the electric motor in the shifter is bad or the electrical motor in the ignition. but truly lost for the correct answer.
May 29, 2019 at 6:51 PM
