No power in drive
2007 NISSAN MURANO
143,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
07 MURAALTENATOR
I put in a battery but ground was too short I understand rewd it from side wall under battery holder. Started up fine I noticed the battery light and brake light were on. Last time that happened it was the alternator. I got a new one and battery and brake light went off. I got to a red light and car only sputtered I put it in neutral and it revved same in park. I pulled off put ground back. And same thing. I turned it off and tried to start. Nothing. I hooked battery then hooked it back up. Started drove until I slowed to a stop and same no power only in neutral and park.
Aug 15, 2018 at 5:40 AM
The negative battery cable concerns me when reconnecting it did you connect the battery/body ground as well as the engine block grounds? Can you upload images of the job so I can see?
Please let us know.
Aug 16, 2018 at 7:31 PM
07 MURAALTENATOR
Yes, I put all back where it was. I think I caused the alternator to go out again.
Aug 18, 2018 at 3:18 PM
07 MURAALTENATOR
I guess I am going to have to learn how to remove and install a alternator.
Aug 18, 2018 at 3:19 PM
Yep, I would use a Denso rebuild. Here is a guide to help you with the step by steps and diagrams below that show you how on your car:
https://www.2carpros.com/articles/how-to-replace-an-alternator
Aug 20, 2018 at 8:53 AM
