No power from coil pack
1988 FORD RANGER
200 MILES • 2.9L • V6 • 4WD • MANUAL
CODYJAMES1
  • 18 POSTS
Just dropped a rebuilt motor into my truck and have all the wiring hooked up correctly, but my ignition coil won’t put out a spark. I’ve tried several new coils and still nothing. I have power all the way to the coil just nothing coming from it, to the distributor cap.
Sep 7, 2019 at 7:26 PM
Good morning.
Take a test light and test for power on the negative side of the coil with the key on.
Then have someone crank the engine and see if the test light flashes. That will tell me if the module is working.
Sep 8, 2019 at 5:50 AM
CODYJAMES1
  • 18 POSTS
When I turn it over with the test light on the negative the light stays solid. Along with the positive.
Sep 10, 2019 at 3:00 PM
That means the module is not working.
You need either an ignition module and/or a pickup coil in the distributor.
Sep 10, 2019 at 3:06 PM
CODYJAMES1
  • 18 POSTS
No power to my injectors either.
Sep 10, 2019 at 3:07 PM
CODYJAMES1
  • 18 POSTS
Or fuel pump.
Okay, with the key on, you have no power to the injectors? That comes from the power relay by the fuel pump relay under the hood.
Did you verify no power to the fuel pump?
Sep 10, 2019 at 3:14 PM
CODYJAMES1
  • 18 POSTS
Correct. No power to fuel pump or injectors with key on.
Sep 10, 2019 at 3:21 PM
I attached a picture of the power relay location.
verify power to the relay with the key on. There should be 2 terminals with voltage.
Sep 10, 2019 at 3:25 PM
CODYJAMES1
  • 18 POSTS
I attached an image of the relays. The middle one only has one terminal with voltage. Red wire with green stripe.
Sep 10, 2019 at 3:34 PM
The green one is the fuel pump relay. The black is the power relay.
Sep 10, 2019 at 3:44 PM
CODYJAMES1
  • 18 POSTS
Okay well the black is the one I tested. The test light only comes on when testing the red wire with green stripe. No other terminals lit up. I’ll get a new relay tomorrow if needed. I’m done working on it for the evening. The truck ran and drove fine until I did the motor swap. Old motor had a broken exhaust manifold.
Sep 10, 2019 at 4:36 PM
OK.
Sep 10, 2019 at 4:55 PM
CODYJAMES1
  • 18 POSTS
Okay, so I bought a new power relay, now have power everywhere I need it and bought a new coil pack. Have power to coil but no spark coming out of coil.
Sep 14, 2019 at 6:48 AM
If you have power to the coil, that means the coil is bad.
Sep 14, 2019 at 6:55 AM
CODYJAMES1
  • 18 POSTS
I’ve put three brand new coils in it already.
Sep 14, 2019 at 7:02 AM
Okay, that is not good.
Can you test for power to the coil?
Use a test light to the positive side. If you do, then test the negative side. Then have someone crank the engine and see if the test light blinks when you have it connected to the negative terminal.
Sep 14, 2019 at 7:07 AM
CODYJAMES1
  • 18 POSTS
Okay, I did that and neither negative or positive blinks. Stays solid while cranking.
Sep 14, 2019 at 7:13 AM
Okay, the module is not working.
It could be the distributor pick up in the distributor or the module.
Sep 14, 2019 at 7:16 AM
CODYJAMES1
  • 18 POSTS
I’ll go ahead and replace that and if nothing changes I’ll email back. Thanks for all the help.
Sep 14, 2019 at 7:21 AM
You are welcome.
Always glad to help.
Sep 14, 2019 at 7:23 AM
CODYJAMES1
  • 18 POSTS
So I had the truck running. But it was a little out of time. Now it’s turning over too slow. Replaced starter, new battery, and solenoid and also have the plugs out. Not sure what to do now. Still turns over slow.
Sep 28, 2019 at 2:31 PM
Okay, use a voltmeter and test the voltage while someone cranks it. Tell me the voltage.
Sep 28, 2019 at 2:50 PM
CODYJAMES1
  • 18 POSTS
The battery voltage?
Sep 28, 2019 at 3:07 PM
Correct.
Sep 28, 2019 at 3:15 PM
CODYJAMES1
  • 18 POSTS
Okay. Gotta find a voltmeter somewhere because I don’t have one. I’ll reply when I test it.
Sep 28, 2019 at 3:17 PM
Sounds like a plan.
Sep 28, 2019 at 3:18 PM
CODYJAMES1
  • 18 POSTS
So I borrowed one from a buddy and when he hit the key the voltage dropped to around 8.5.
Sep 28, 2019 at 4:30 PM
Not good.
I would clean the cables real good both inside and outside and retest.
Is the battery voltage 12.6 with the engine off?
Sep 28, 2019 at 4:32 PM
CODYJAMES1
  • 18 POSTS
12.2, but that should be plenty I think. New terminals too but I’ll redo them and try it out.
Sep 28, 2019 at 4:38 PM
12.2 is only 35% of battery capacity. Charge the battery to 12.6 volts and retry.
Sep 28, 2019 at 4:45 PM
CODYJAMES1
  • 18 POSTS
I pull started the truck and it fired up as long as I gave it some throttle. But the back of the intake is building up condensation on it and is actually feeling really cold when the motor is running.
Sep 29, 2019 at 8:47 AM
CODYJAMES1
  • 18 POSTS
Also, it is misfiring like crazy and won’t idle.
Sep 29, 2019 at 8:48 AM
One thing at a time.
Did you charge the battery and retest the starting?
Sep 29, 2019 at 1:10 PM
