Intermittent no power at start?
1997 JAGUAR VANDEN PLAS
87,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DONNIE J EDWARDS JR
Accessory key position all function properly. Turn the key to start, all power gone and goes black. Have to disconnect/reconnect the battery to correct and then she starts fine. Only happens intermittently.
Sep 24, 2022 at 4:37 PM
What you described sounds like a connection issue. Does this happen every time you try starting the vehicle?
Do me a favor. Take a look at this link. It discusses what you described and how to fix it. Let me know if it helps.
Sep 24, 2022 at 11:23 PM
DONNIE J EDWARDS JR
Your assistance corrected the problem. The negative side of the battery terminal was loose. So far everything seems to be working fine. Thank you.
Sep 26, 2022 at 11:44 AM
