Okay, go after the pink/green wire next with the Key On.
You haven't lost comms with any other modules and that one power wire ties the 2 modules together,
Do you have an oscilloscope?
The 2 modules run on different networks, the HVAC module has lost its comms on the Interior CAN bus network and the Humidity sensor communicates on the LIN bus, they are completely different signals, that's why I think there is a loss of power on that Ignition feed wire, if they are both missing power we'll need to trace it back to fuse 99.
It also goes to this in-car temperature sensor. it might be that the temperature sensor is shorted out and pulling the 12-volt feed down. so you might have to unplug that at some point. I'll try to find its location.
The last 4 diagrams are the in-car temperature sensor.. Should have the same Pink/Green wire running to it with 12 volts.
Okay, the temperature sensor is not on any network, its hard wired in, so its just like a thermistor that changes resistance with temperature. Just like a Coolant Temp sensor, so it could pull down the 12 volts without potentially blowing the fuse.
Aug 3, 2022 at 11:16 AM
