No power
2006 HONDA CIVIC
160 MILES • 4 CYL • AUTOMATIC
VAL VAL GIACONA
I have replaced battery, battery cables, and alternator and I still have no power!! Doesn't make a sound when I turn the key. Just nothing.
Jun 4, 2020 at 8:55 AM
CARADIODOC
  • 34,306 POSTS
The most common suspect is a loose connection at the under-hood fuse and relay box. Follow the smaller battery positive wire to that fuse box and check that connection.
Jun 4, 2020 at 4:51 PM
When you say you have no power, what happens when you turn the key? Does the cluster come on and the starter just does not turn over or when you turn the key nothing at all, no lights, gauges, starter?
Let me know and we can figure this out. Thanks
Jun 4, 2020 at 5:02 PM
