Hi and thanks for using AC
This could be several different things. However, if the check engine light has come on, I recommend scanning the computer to determine where the problem is coming from. Here is a video showing how it is done:
https://youtu.be/YV3TRZwer8k
If you find there are no codes, I would recommend checking the catalytic converter to see if it is plugged. Here are common symptoms of this issue:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link which describes how to check for a converter issue:
Do these things first and let me know what you find.
Jul 16, 2018 at 8:19 PM
