No power
2000 MITSUBISHI MONTERO
165,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
DESWIGER
Replaced exterior fuel filter, checked all hoses and vacuum. has no OBD-II codes, no apparent electrical problems, shifts fine (but just a bit high on rpm's between gears) and yet there just does not seem to be good pick-up and it is burning through fuel more than usual.
Apr 7, 2017 at 11:24 AM
O yes, the high shift points, i sign that the catalytic converter is becoming plugged giving you low engine power, here are a few guides that should help you get the problem fixed.
and
https://www.2carpros.com/articles/catalytic-converter-replacement
and
https://www.2carpros.com/articles/engine-has-low-power-output
Best, Ken
Apr 9, 2017 at 2:59 PM
