Installed new disc brakes front , a new 1 inch bore dual master cylinder with power boost , under floor mount master cylinder , new brake pads and calipers for the rear. bled the brakes , front work fine , bled the rear , no pedal and when trying to pump up the rear , pedal becomes real spongy . i have 2 pond residual pressure vales on front and rear , i have used air to blow out all lines before bleeding the system . i blocked of the master cylinder and stepped on the pedal , good and solid , i blocked off the rear to check the front , good brake pedal , blocked off the front and no pedal to the rear , i open the connection fitting on top of the third member rear end housing being the highest spot to check for air , all was good .i have used about 2 quarts of brake fluid .
Sep 10, 2021 at 8:42 PM
