Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Safety
Traction Control
No passing gear
2009 DODGE RAM
146,345 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ROBERTO TORRES
MEMBER
1 POST
FOLLOW
The truck runs as if the traction control is tripped.
Dec 13, 2018 at 4:42 PM
CERTIFIED EXPERT
Good evening,
Not much to go on here. Is the check engine light on?
I will give some ideas.
1. Low fuel pressure. I would have it checked to be sure there is sufficient fuel to the injectors.
2. Catalytic converter clogged. if the exhaust is blocked, the engine cannot breather and will not run right.
3. Make sure the brakes are not hung up anywhere.
Dec 13, 2018 at 5:37 PM
