no oil pumping in the right side of the engine
1999 FORD F-150
350,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ICEPRO
  • 4 POSTS
No oil pumping in the right side of the engine ....new oil pump ..new timing chain
Starts fine but no oil pumping
Sep 23, 2015 at 5:41 AM
HMAC300
  • 48,601 POSTS
you'll have to check for a blockage on the passage leading to head. there are two different engines on this vehicle.
Sep 23, 2015 at 6:45 AM
ICEPRO
  • 4 POSTS
The engine is a 5.4 ford f150 engine
Nov 12, 2015 at 4:32 AM
HMAC300
  • 48,601 POSTS
what vin is the truck there is vin LNov 12, 2015 at 5:50 AM
ICEPRO
  • 4 POSTS
Yes vin L
Nov 13, 2015 at 4:33 PM
HMAC300
  • 48,601 POSTS
as I said it has to be a blockage if the cylinder heads were removed then you have the head gaskets on the wrong sides because they are NOT interchangeable. recheck your work . oil not going to one side from just replacing timing chain would still go to each head unless a blockage.
Nov 14, 2015 at 7:10 AM
