no oil pressure or water flow
2001 DODGE DAKOTA
RAYMONDJOHNSON
I had the head gasket fixed and now I have no water flow through radiator and no oil pressure to where the check gauges light is on what would cause this? it has never done this until I had the head gasket fixed.
Oct 16, 2013 at 3:48 PM
JDL
  • 16,098 POSTS
I can't comment on the work you had done, I can't see anything from here. As far as oil pressure, maybe a wire connector was knocked loose from oil pressure sending unit?
Is the engine overheating? Remove the thermostat, hook everything back up, minus the thermostat. Now do you have coolant flow? With crossflow radiator, you can drain the coolant down just till you can see the top couple of coolant passages. Without the thermostat coolant flow should be instant with engine running. If no coolant flow maybe water pump or clogged engine? With belt driven pump, the belt is on, correct?
Oct 16, 2013 at 4:24 PM
