Starter issue
1989 JEEP WRANGLER
35,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
JAMES STEVENS2
Starter grinds will not start. changed flywheel, starter, battery and clutch still grinds. The Bendix on starter is not meshing with the flywheel. Tried everything that I can think of, was suggested that I get a Ford starter with a longer nose what do you think?
Nov 16, 2017 at 2:31 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Was that a Mitsubishi starter that you took off and put on?
Nov 16, 2017 at 3:34 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You should check the pinion gear clearance and here is the procedure showing how.
the Motorcraft starter I read as being for the 87-88 4.2 engine.
Nov 16, 2017 at 3:41 PM
