Low beam headlights do not work?
2015 MITSUBISHI OUTLANDER SPORT
150,000 MILES • 2.0L • 4 CYL • AUTOMATIC
JEFF HERMAN
  • 486 POSTS
The two bulbs on the passenger side that are supposed to light when the low beams are turned on don't. There is power to the blue wire in the connector. I suspect there is a breakdown possibility somewhere in the headlight assembly. I tried to test for continuity from the connector to the bulb socket, but I don't understand the pathway for ground and current. These are HID lights. I also have continuity from the harness connector to the connection on the back of the bulb which is new. Hopefully your site will upload my photos. Apparently, it won't. I had this issue before, are others having the same issue?
Apr 24, 2025 at 12:00 PM
Nope they upload just fine. Can I ask which phone you have or what kind of image file? Chances are the control unit inside the headlight is bad. Here is a wiring diagram for the unit in question. Check out the images (below). Please let us know what happens.
Apr 25, 2025 at 10:00 AM
JEFF HERMAN
  • 486 POSTS
I don't think it's the correct assembly. These are HID lights and there are more wires and none of them connect directly to the bulbs.
Apr 25, 2025 at 1:35 PM
I double checked, this is for the HID system. The other wires must be for the running lights?
Apr 27, 2025 at 11:32 AM
