Yeah, I would think so, if you look at this circuit though, they have this rear marker lamp that is a parallel circuit between the turn signal and the taillights. It's underlined in orange in the diagram below. Did you replace that lamp too with a LED? That looks like a circuit where things might get complicated. It makes the marker lamp blink with the turn lamp when the turn signal is on, but then if the taillights are on, no turn signal, the marker light is then in series with the turn signal and in parallel with the taillight bulb that's part of the stop lamp bulb. So that will leave the turn signal, and that marker lamp both slightly dim because they're on the same power feed, its crazy how they designed it. Maybe that marker bulb burned out on the other side and is not affecting the circuit and it's working correctly.
There has to be some slight difference in the 2 setups from drivers to passenger side. I went through this over and over, trying to figure out exactly how the circuits are working, but when it comes to these conversion kits, it's all about current flow. LEDs pull almost no current, hence the resistors.
But maybe trying to unplug a few things, one at a time, and you can find out where the change is. But I do agree with you, if both sides are setup the same, then throwing the logic chips in there, and it can end up being a rabbit hole you go down, and never get out of.
Aug 28, 2022 at 1:27 PM
