there is no hot air coming out from the blowers.
I changed the climate control panel the thermostat.
wash out the matrix.
the temperature of the car is seventy five degrees or even lower if i turn the climate on.
if I keep it closed (off) it will go to ninety degrees as it should be.
when the temp is at ninety degrees and I turn the heater on it will blow hot air for a few seconds and the the temperature of the engine will start falling again and it will start blowing cold air again.
can you help me?
can you help me?
Jan 25, 2017 at 3:19 AM
