No heat from vents?
2014 BMW X5
157,099 MILES • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I replaced this n55 motor. I didn't have to disconnect any of the heater hoses or the hoses at the heat control valve, but of course all the other coolant hoses were removed. I installed everything and all is good. But no heat from air vent.
Jan 1, 2025 at 9:38 AM
If when the other engine went out if they used head gasket sealer it could of clogged up the heater core so I would remove the heater hoses and try a flush, also, these car had a problem with the heater control valve for the heating system so I would check that at it as well, here is the location and a video to help go over failure issues as well.
https://www.youtube.com/watch?v=SNRb6pSwYuU&t
Jan 1, 2025 at 3:27 PM
BHAMDOC1973
  • 2,008 POSTS
No the coolant was clean. Only the engine oil looked weird. And i added all fresh coolant. I'll remove the heater control valve and see.
Jan 1, 2025 at 3:50 PM
Sounds good, let me know what happens.
Jan 2, 2025 at 10:15 AM
BHAMDOC1973
  • 2,008 POSTS
I also checked the cap on the coolant expansion tank and found this, do you think it would affect anything?
Jan 3, 2025 at 10:04 AM
Yes, it could make the engine overheat. are both heater hoses hot when the engine is warm? If not, I would look at the heater core being clogged or the heater control valve. Also, these cars have a water pump just for the heater.
Jan 3, 2025 at 11:58 AM
BHAMDOC1973
  • 2,008 POSTS
Don't think they have a water pump for the heater, I will see what the heater control valve does. The car does not overheat at all. Do you have instructions on the heater core? I think dash may have to come out if so.
Jan 3, 2025 at 12:00 PM
Yep, the dash will need to come out to fix it, but I would use a garden hose to see if you can unblock it.
Jan 3, 2025 at 12:04 PM
BHAMDOC1973
  • 2,008 POSTS
There are 3 hoses going into the firewall, all 3 I think come from the heater control valve, how would I know which ones to feed water to see if it comes back out from another hose?
Jan 3, 2025 at 12:09 PM
It looks like all three go to the heater core. So, all of them should be hot. Check out the images (below). Let us know how it goes.
Jan 4, 2025 at 11:04 AM
BHAMDOC1973
  • 2,008 POSTS
I swapped the valve control and got some heat after waiting few minutes, ill check it more after i get this vac hose swapped which broke while replacing the control valve.
Jan 6, 2025 at 11:07 AM
Okay, it sounds like you may have fixed it. time will tell.
Jan 7, 2025 at 10:21 AM
